volvo 3.0 gl/sx max trim / right prop
pemar.s
I have a wellcraft 18sx 1996 is its not possible to trim to transport level, there are no additional swithes on the handle or on the dashboard how can i trim to transport level?<br /><br />The boat has a 14,5 x 19 prop what is the best size for waterskiing?<br /><br />Does someone know where i can find additional info about a wellcraf 18 sx?<br /><br />Regards <br />Peter<br />Netherlands
Blk-n-Blu
Master Chief Petty Officer
Re: volvo 3.0 gl/sx max trim / right prop
Some shift/throttle levers have an up/down button on the left side of the handle and the trailer botton on the right side so using the right thumb and forefinger squeeze both at the same time. Maximum RPM will help determine the right prop. Look here;<br /> http://www.marinemechanic.com/specs/volvo3-4.htm.
cobra 3.0
For water skiing, I would go with a 17" pitch for better hole shot if your 19" seems a little slow off the start. Just be aware that you have a maximum recommended rpm and you shouldn't exceed it. It's 4600 rpm for my 1986 Cobra 3.0.
Elk Chaser
The "trim" switch is set up with a limit switch on the side of the drive. This limit switch prevents you from trimming the prop out of the water. You absolutely must have a "trailer" buttom somewhere. <br /><br />On my 1989 Wellcraft it was on the throttle/shift lever mid way down the shaft. It was not a switch, it was a button. I've seen many others on the dash. It must be somewhere.<br /><br />What is your RPMs and speed with the 19p prop at full throttle and how quick does the boat get out of the water?
pemar.s
My RPM at max speed is 4650 recommend max of volo is 4600 so this is ok. I fi want to change to stainless do i need onther size than or stick by this size stainless will give a better performance?<br /><br />Guys I've been searching the whole boat but honestly ther's now extra trailer button.<br />Maybe not on this handle and do I need to install on myself does some know wire colors?<br />Where is the limit switch installed?<br /><br />Thanks <br />Peter
tommays
on my 1995 control it is hidden on the lower right corner of the control faceing it <br /><br />the buton is not really well marked it is so flush with the control that it is allmost hidden<br /><br />i think it like this to keep from useing it while underway by mistake<br /><br />tommays
rodbolt
the SX I dont think used a trailer switch. measure the ram when fully extended. it should be a few inches from the length of the cylinder. you may be low on fluid. or someone may have installed limityers in the rams for some reason. the drive wont trim up higher than the hull. is this a new problem><br /> good luck and keep posting
pemar.s
Originally posted by rodbolt:<br /> the SX I dont think used a trailer switch. measure the ram when fully extended. it should be a few inches from the length of the cylinder. you may be low on fluid. or someone may have installed limityers in the rams for some reason. the drive wont trim up higher than the hull. is this a new problem><br /> good luck and keep posting
Thanks but thats the biggest problem the drive will not even trim to same level of the hull, it just trim to beach level so drive is still under hull, I'm also no low at fluid could be they installed limiters?<br />But how can i verify (thru wire colors i.e.) the drive is not limited by electrical switch and might be possible be trimmed higher?
