Re: volvo 290 DP seal kit?
they make both an upper and lower seal kit. one is about 80 dollars and the other is about 115.<br /> takes two special tools to properly locate the prop shaft seals. one for the bearing box and one for the tube gear seals. seal kits will have instructions on the proper assy and tool use for the lower. you need to get the manual for proper dissasembly of the shifter housing. mess up driving the cam pin out and it will junk the housing. the assy is about 300 dollars. also takes some speacial tools to properly replace the crush sleeve in the upper bearing box. instead of the string and spring scale method,only if I am reusing the original bearings, I take a rolling torque reading with a dial type inch pounds torque wrench and reset the rolling torque to that spec aafter reassembling the upper bearing box. carefully tag all shims for the upper housing cap, upper housing to intermediate and upper bearing box so they all go back in the correct location. carefully mark the position of the upper gear shaft bearings so you dont mix them. shifting problems may result. do you have a factory DP manual ?<br />if not you really need one. while a simple seal job is within the capeabilities of most shade trees its imperative to follow the correct assy procedures for seal placement, rolling torques and shim pack replacement.
