First off I would like to thank all who reply in advance for the help and knowledge. I just bought a boat powered by a Volvo 131 with a 275 outdrive. There are a couple of problems and they are all contained in the transom shield. First the tips of the ears that holds the pin that the out drive rests against (when lowered) are broken off. Second the shield has a crack in the boss that the tilt motor runs through. These are probably related some how. I though about just using a transom saver when towing the boat to keep the pressure off of the tilt motor and shield, but that is just a bandaid. I would like to replace the shield and install new bellows while I am at it. How hard is this to do and where is a good source for parts? I worked and was schooled as an auto tech, so I am not too stressed at this point. I have just never removed an outdrive or the like.
