1]I have changed the u-joints. <br />2]Have checked the prop shaft and changed to a new propeller. 15-17R <br />3]Tightenend all bolts associated with mounting of engine and stern.<br />4]No engine vibration at idle or acceleration.<br /><br /> PROBLEM<br />It starts grumbling at about 5mph and continuse to do so until on plane and then evens out.A large amount of curning in water an eruption.On turns its is on right hand turn that it acts up or when trolling slow only on turns.Mostly right hand turns.The steering seems also lose not as tight as it was when not making nose.Will contiusly pull to the right.<br /><br /> Questions<br />There is no gimble bearing but a main shaft bearing.Could this be the problem?If so can this be changed with just removing the upper gear housing and going at it from there.<br /><br />Could there be a alighment problem and if so how do you correct it.Have clymer manual and does not cover.<br /><br />Last but not lease could it have to do with the bushings on the mounting collar and fork.<br /> thanks fish
