The volt meter tells you how much charge is in your battery, indirectly.. If voltage drops <10V while cranking, its time to charge the battery or replace it. I dont know what amps will tell you thats useful, besides calculating how long you can run accessories before you drain battery. You should know that anyway (2.5 amps VHF, 1.5 amps depth, etc, (or whatever the actual # is)
