vip prop
bossvip
17' vip vison 2.3L omc I/O what size prop should i be using?
other problems are
89 vip 1750 2.3L omc and she back fires at times i give it full throttle and chugs, and she dies.
ive changed the plugs, wires, coil, timing, points and still does the same. i was told it could be the cam.
can you help me out or have any info that could
thanks
jestor68
Re: vip prop
Did you check the carb's accelerator pump for proper operation?
bossvip
Re: vip prop
i havent yet but i will. i was told today it might be the gas sniffer?
your thoughts on that
