Hello, a local marina closed last summer and was selling things very cheap. I picked up a 2003 Bayliner with a 3.0L mercruiser alpha 1 gen 2 drive. The engine had not been winterized properly and had a cracked block. They sold with it an older mercruiser 140. The whole package with trailer was $500. They said their plan had been to put the 140 in the boat to replace the 3.0L
Will I need to completely dress the 140 with all the components of the 3.0L. Ignition system, exhaust manifold and riser, carb, flywheel and coupler? Can I leave the output end of engine the same (with old flywheel and coupler, but just use new bell housing)? I would still need to swap exhaust manifold too which is fine. I've just been told I won't be able to attach the flywheel and coupler from the newer 3.0L to the older 140.
Thanks in advance.
Thanks in advance.
