I have a Karavan roller trailer for 23ft walkaround and need some advice or tips please.<br /><br />If bunk trailers can be unhooked before the boat is backed into the water and once the boat starts to float I guess it will slide off the bunks, what is the correct or easiest way to unload a roller trailer without taking a bath since you would have to wait till the tension is off the cable/strap before you can unhook it? Same question when loading, you can power up the bunks until friction holds you then hook it but with rollers you roll back into water.<br /><br />Should I submerge the trailer until the transom floats when unloading or just back up till transom hits the water and winch it out the rest of the way? Same with loading? <br /><br />Thanks.
