gnarleygnu
- Apr 1, 2010
- 9
So I have the manual for my make/model of engine, and I've searched the net and iboat forums and am still stuck.
My manual implies it's quite simple to drop the gearcase: simply unscrew the 4 bolts, shift into reverse, rotate prop to align seal support pin, gearcase drops, unscrew connector screw etc.
I have tried everything under the sun to get my gearcase to drop, I've slowly turned the flywheel (clockwise) while pulling down on the gearcase to try to line up the pin and get the gearcase to drop: no luck. It is only dropped about 1 mm, maybe 2mm.
I reallyreally don't want to pull the powerhead, I just rebuilt the carb and put everything back together...
If anyone has any insight about possible solutions I would be much obliged.
Thanks!
Thanks!
