Trolling Motor Mounting Advice
Endeavor
I am buying a 17FT Key West and want to add a bow mounted trolling motor. I have never mounted one on a fiberglass boat. Is this something that can be done easily? Not sure if the mounting area will allow access for through bolting. Any advice, cautions, etc. would be appreciated.
Ranger354
Re: Trolling Motor Mounting Advice
If there is no through bolting, they make some rubber inserts. You will have to drill holes, so make sure all measurements are correct. A couple of stainless bolts and your done.
