Re: Trimming up a small engine
I would say a prop change would make a difference but you need specifics to make sure you dont over-rev your O/b. If you can find a shop tach to borrow from a buddy and see what RPM you are turning at WOT, then you can see whether or not you need less pitch or different prop to allow for higher rpms at WOT. If you are in rec. range, you should not do anything to motor/setup except play with weight and distribution of weight to allow for easier plane. Of course, this is just my opinion. Sounds like you are setup okay anyway. If you give specific weight of rig,model # of motor,rpms at WOT,type and size of prop you have now; then one of these prop gurus like Dhadley could help you determine what would be best for top speed. Good Luck
