vissertrades
- Aug 16, 2003
- 79
Hi,<br /><br />My '95 50 hp Johnson's trim/tilt developed a knocking noise on the down stroke only. I've checked the pins/bushings and they rotate freely. I operated the trim/tilt while it was not connected to the engine and the noise was still there. I checked the fluid while unit was vertical and that seems fine. I've bled the system per the manual and noise stops, but then re-appears when the trim motor cools down (10-15 min). This is driving me nutz!!!! Bleeding proceedure was to cycle up and down a minimum of 5 times while holding trim button on for 5-10 sec at each end of stroke. After 4-5 cycles the knocking noise just stops! Electric motor is warm to the touch. This noise just started when weather turned cold (40 or so). <br /><br />Any help before I bring it in to the shop would be great!
