Rranger
- May 18, 2009
- 449
Can you bleed a 1994 125hp merc trim tilt pump on the work bench. while on the boat I had the electrical motor working fine, and it was holding a bit once I’d lifted it by hand and locked it, then primed it. Then unlock and would hold for awhile then go down, but couldn’t get it to lift. Even after multiple primes. I’m hoping this will fix it.
VALVE KIT-TRIM (#811678A6) | PerfProTech.com
Buy VALVE KIT-TRIM (#811678A6) from PerfProTech.com
www.perfprotech.com
