My Alpha 1 Gen 2 seems to be having a hard time trimming all the way down. The pump runs but the outdrive needs a push now and then. I believe that the trim rams end caps are likely due for replacement. I’d rather not try to remove the rams as the hose fittings may be hard to get off.
Can I pull the rear pin on the rams and then loosen the end caps and take the piston assembly to a bench vise and leave the ram housing still attached to the outdrive by the front pin?
Looks like I need part # 8M0118340, does this come with the end cap seals and everything I need?
