travel time/ speed zone
kusboat
Does anyone know the travel time from Jupiter to New Symrna Beach FL on the intercoastal or is there a web site that will show the speed zones between Jupiter and New Symrna.<br />Thanks for the help
bomar76
Re: travel time/ speed zone
The distance from planet Jupiter and Earth will vary greatly....at it's closest it's 365 million miles.<br /><br />Go to this page : http://www.fourmilab.ch/cgi-bin/uncgi/Solar/ <br />and it will give you todays distance to Jupiter and any other planet....and if you select the option to enter some other time (as in your proposed fishing day) it will give you the distance on that date.
tgissel
unbelievable answer there :confused: :confused: :confused: :confuse
bomar76
That link is confusing to some as it gives the distance in A.U. (astronomical units ...the mean distance from Earth to Sun).<br />Need a correction factor?
SwampNut
Are there any fuel stops available on that route? Betcha BOAT US towing doesn't cover you even if you have the "unlimited" towing coverage.
haddles
151 miles. I assume by road.<br /> http://www.geobytes.com/CityDistanceTool.htm <br />Or this one. It's a marine map of your area but i'm not sure it has what you're after. You can move around and change the zoom and enter other destinations as well.<br /> http://mapserver.maptech.com/homepa...CFID=4331901&CFTOKEN=73955684&&latlontype=DMS <br /> could also try google earth or NASA worldwind.<br />If you are planning on going to the other jupiter i'd recommend a rocket and not a boat ;)
kusboat
Are some people that clueless? A boating forum why would I want to go from the planet Jupiter :confused: :confused: :confused:
eli_lilly
It's manatee season down here so there are a lot of idle and no wake zones in the intracoastal. You'd probably have a much faster trip oceanside. I wouldn't use the Jupiter Inlet, though, unless you are familiar with it. Use the St Lucie or Lake Worth inlets.
watered down
Originally posted by kusboat:<br /> Are some people that clueless? A boating forum why would I want to go from the planet Jupiter :confused: :confused: :confused:
Maybe he's home sick :p
haddles
Jupiter is 588 million km from earth. i'd guess you'd need about 60,000 fuel stops in your boat. i'd probably allow 200 years for the journey. Hope this helps. :)
