I have a Boat trailer a little over a year old, very limited trips on the tires yet the left and right edge on one side has no tread left and the other side has the inside severely worn. Is this a misaligned weld of the wheel assembly to the trailer or cheap tires? The tires say 50 lbs max pressure and I have about 44lbs now. I added some pressure to try and keep the wear more toward the center of the tire. Should I be running more pressure? I'm guess when making turns its eating the tread away.
Thanks
Thanks
