vissertrades
- Aug 16, 2003
- 79
Anyone know what is typical for clearance between the top main bearing and crank journal? Motor is a '95 50Hp 2-cyl Johnson. Looking at the service manual the top journal has the most tolerance of the three, 0.005". I keep going back to the fact that I can "feel" radial play when pushing the flywheel fore-aft and less/none side-to-side. I recently re-torqued the upper main bearing bolts and that significantly reduced the "play" but there's still a hint of it left! Maybe due to cool weather as it was 35 degrees out last time I monkey'd with it. Also, hint of play would go away and return based on crank rotation. If I had to guess I'd say play was around 0.02-0.03" before re-torque and 0.005-0.01" after. Flywheel turns freely and motor has NOT been run after re-torque.<br /><br />Thanks!
