You may have a timing problem if you always arrive late to places.<br />Also if your engine consumes too much fuel, rattles or doesn't want to idle, makes explotions or kicks backwards when starting. Does not develope full power or acceleration is poor.<br />Cheers
after it starts it hard to take off with out it dying but once it warms upo it will start fine and run fine but takes awhile for it ti plane i have a planing fin but it rides with the nose in the air for a good while then it will plane out but to me it takes a while for it toplane.
Compression is only 1/3 of the equation. Spark and a good fuel supply count just as much. After running it for awhile shut it down and pull the plugs. If one looks obviously different that is your problem cylinder. If it is not as wet with fuel it is either a plugged carb jet or stuck reeds. If it is soaked you are not getting good spark.
