WHen my tilt trim is in the water it makes a horrible grinding/ binding noise. I think it could be that is has a bad seal and it is letting in water but I am not sure. but it works fine some times then it will make that noise in or after it has been out of the water for a few days it will work ok until you get it in the water
second it also will not keep the engine trimmed up on the center cylender when giving it gas the engine falls on the two side posts.
finally I noticed that the side posts move back and forth a hair in mine and are firmly in place on other tilt and trim is that a problem??
I checked the fluid level when the pump whas all the way down and it worked fine. did I let air in the system and that is why it is not working correctly?? WHat is that grinding noise it makes the trim move very slowly and uses alot of power.
I have a merc 135 95 black max
