Sept Last year I bought an 88 Sea Ray Seville Bowrider for cheap. Ran pretty good and drove good in the water. Went to change the oil and saw cracking in fiberglass engine mounts. Started peeling away to find the wood inside is pulp.
Long story short I began pulling everything apart so I can get room to replace rotten wood. But found a couple things that seem odd to me.
First, The top nut on front engine mounts weren't tightened down to the washer and there was visible thread between nut and the mount, same for both sides .
Next comes the rear mounts. Looking at the photo, it seems the washer should be bigger, and on the bottom of the spacer to actually hold down the mount? it seems there is nothing holding it down onto the rubber isolator besides the weight of the engine? again same for both sides.
Third, the gasket between the stern drive and the bell housing was used in conjunction with silicone.... not the biggest issue I guess. When I separated it though gear oil came pouring out and was plenty up in the bellows, which is probably why the U-Joint works so smoothly (not loose, just smooth). Is this due to a bad seal, specifically number 17 found here? ( https://www.perfprotech.com/mercury-.../70?model=4239 )
So what do yall think? The rear mounts have me most concerned because I planned to put everything back the way it came out, but if its not right then I won't be doing that.
Any other pointers or things to do while I have all this out. I plan to do water pump impeller ad a few other wear items, Note that in the floor panel pics, I actually pulled the two wood seat panels out of the larger grooves in the photo. Whoever did the glass job did not do it correctly.
