Re: Temp Gauge
Howdy,
Your temp gage is a fairly simple device.
Think of it as an ammeter (it actually IS)
It measures the current passing thru the sender (which is grounded to the block).
The sender is a variable resistor that changes resistance INVERSELY with temp.......I.E. temp goes UP, resistance goes down. (when the resistance goes DOWN, the gage indicates MORE current and goes higher.)
If you (like suggested above) short out the sender with a piece of wire to anywhere on the block. (with the gage still connected) the gage should go to full scale.
If it doesn't, the wire from the gage to the sender is "open" or broken.
OR, the 12v power to the gage is disconnected, or a fuse is "open" (blown)
OR, the gage is defective.
Your oil pressure gage works (and is wired) the same way.
Cheers,
Rick
