Hi, I'm working on a 140 4Stroke Model J140PL4ST.
It has an overheat problem...I checked the water pump it is good and changed the thermostat.
i have a infrared temperature gun and noticed the bottom half of the cylinder head is running about 87 degrees at idle and the top half is about 150 at idle. with a steady climb in temp as rpm increases.
i'm running it on a hose with no load.
could it be a blockage in the water passage somewhere?
what is normal operating temp for this engine?
any help would be appreciated...I'm new to Johnson/Evinrude
Thanks,
Thanks,
