tell tale water spraying not streaming
tenacrewoods
I have a 1995 40hp Tohatsu model#M40C ser#361A88284 I was running out on lake yesterday when motor bogged(sounded like I ran thru weeds)just for a second but i was in 20' of water with no weeds in site.Motor now sprays like a finger on the end of water hose instead of good strong stream.Is there an easy fix, can motor be back flushed,what do I do.I immediately shut motor down and trolled back to ramp.Any Help would be appreciated.<br /> Thanks!<br /> Mike E
Spidybot
Re: tell tale water spraying not streaming
Sounds like something got stuck in the water channel just behind the pee hole. Try to clean it out with some small item. If you get something rubber-ish out, it may be fragments of your impeller.
D
DJ
Guest
tenacrewoods,<br /><br />When is the last time you replaced the impeller? It may be time.
ezbtr
Yup sure sounds like you got either something stuck in water tube (dirt or impeller parts) or just lost impeller. I just changed mine out myself on 40 hp Merc, fairly easy and cheap job. $25 for impeller(didnt replace impeller plates - looked good),Boy do I **** out a stream of water out tube now! I used some unwrapped solder line to clean out tube also. Good Luck, Heinz
