Tell tail
gatorguy
Tell tail not as strong as last run.<br />Engine does not overheat.<br />Could this be a clogged pee hole or a water pump problem??<br />Johnson 175 hp.<br />Model No. J175TXCCM<br />Thank you for for any info.<br />Lee
ob
Re: Tell tail
Could be a clogged line or tap fitting.When was the last run?
gatorguy
Re: Tell tail
Hi OB;<br />Last run was yesterday when I noticed the problem but before that, two weeks ago and everything was OK then. I'm going to check for clog in the line tomorrow, (55 mile drive). I'll let you know how I make out.<br />Thanx for the reply.
ob
Re: Tell tail
Good luck.Hope it's just a clogged line.We'll be looking forward to hearing back from you.
gatorguy
Re: Tell tail
Hi OB;<br />I took off the hose from the block and fired it up. had a very strong stream at the block. <br />Then blew out the hose, hooked it back up and everything is OK now.<br />Thank you so much for the response.<br />Regards, <br />Lee
