HI
I'm new to this forum.
Anyone know SEARS TED WILLIAMS 7.5 HP. OUTBOARD MOTOR - 21758881 .
The motor is in mint condition. The carb was removed and disassembled. I got the motor intact with the carb removed and apart. I put it back together. I don't know if everything is there or not. Anyway when i pump the bulb it fills the bowl and the cylinder with gas. the gas goes straight through and doesn't pump tight. Once i get the gas clear the motor runs till the bowl is empty the fuel isn't pumping normally the engine stops till I pump it up then it floods REAL BADD again.
Anyone know what the problem is?
I didnt take this thing apart so I'm guessing if I could see an exploided view It would make a difference. Thanks for any help you can offer.
Thanks
ZITON
Thanks
ZITON
