tach reading too high......help
fishinaddict
Hey guys,
On my 93 200 Johnson, my tach seems to be reading correct at idle, but when I am running it is reading like 6000 and fluctuates. What could be the problem?????
ezeke
Re: tach reading too high......help
Your motor can run 6000. It probably has a rev limiter in the powerpack at 6,700.
If you want to get it down a bit you would need to increase pitch on your propeller.
Be sure to use a second means to verify the RPM before spending money on a propeller.
fishinaddict
How can I check the tach?? My prop is 15x17. The motor just dont sound like it is running 6000.
ezeke
Borrow a digital inductive timing light with a RPM read. You just clamp the fingers around a spark plug wire. If you do your own work, you can use the device a lot.
You can also get an idea from the speed. The maximum theoretical speed at 6,000 RPM for a 17 pitch prop on your motor is 51.97 MPH.
fishinaddict
Im pushing a 1983 248 wellcraft sportsman. Top speed is about 38 mph. I cruise at about 30. The boat weighs 3750lbs dry. prob 5500 fully loaded. I thought that was pretty good. What do you think????
