Re: system ground draining battery?
It may be tough w/ an amp meter. Get a 12 volt test light, pull the neg. battery cable, hook up one side of the test light to the cable, the other side of the test light to the neg. battery terminal, see if light goes on. If it does you have a voltage draw. Then start eliminating circut by circut until the light goes out. You do not say if you have a battery switch, & if you shut the switch or not. Better to pull out 1 fuse at a time, to see which makes the light go out. It would be helpfull if you tell about boat & engine, outboard, inboard, i/o, Alternator, or generator. Good luck , Joe
