If a float is stuck down or filled with gas and held down you will get a constant stream of fuel into the offending carb.
You can try to rap on the bowl ara to see if it's stuck and will free it's self. If not. You will need to remove the bowl and fix the reason.
Seeing as it has been sitting. I would go ahead and rebuild the carbs and go from there.
mike
