steering arm link
jeffers
Does any one know where I can get an adjustable steering arm link for a 90hp Nissan 2001 model? I need to straighten my steering wheel on my boat and they're no other adjustments I can use.
12Footer
Re: steering arm link
Most marinas sell an adjustable ball bracket that can adjust the steering.<br />But if you just want to straighten the wheel out, you can remove the wheel from the helm,and replace it wherever it is comfortable to you,and it'll be a bunch cheaper.You might need a steering wheel puller, but mine allways came right out when I used a rubber mallet on the loosened nut.<br />Be carefull if you opt for the latter,as you dont wanna "mushroom" the threads.Just run the nut out to the end of the threads and give it a good whack or 2 or 3.<br />Also,there is a key in the helm shaft,so don't forget to re-install the key if it falls-outta the shaft way.<br /><br /><br />------------------<br />Time to change my tagline
jeffers
Thanks 12footer,<br />But I did remove the steering wheel and there is only three positions for the key and none of them are straight. I guess I will have to drive with a crooked steering wheel huh.
corm
Take the cable out of the stering head, reposition the wheel ad re install the cable.<br />It involves some trial and error but it's free.<br /><br />...have fun...corm
