Dave Brick
- Jul 14, 2010
- 63
Every time I see a thread about my motor, or a similar motor (mine is a '92 60 hp ELENE, but other threads about 60-70 hp late '80's-early '90s are getting more frequent), A recurrent theme comes up.
Overheated #2 cylinder. Apparently at least 3 service bulletins about this.
I bought mine completely rebuilt (by a very reputable shop). I have the tan/blue wire, going to what I believe is a temp sensor. But I think my tell-tale hose is at the factory position, at the port side of the head, instead of the re-route to the top of the head. So I think I have perhaps part of the service bulletins dealt with, but not all of them. Should I ask the shop to complete the re-build in accordance with all the service bulletins?
The shop removed the VRO, and I use pre-mix.
So, I wonder. How important is it to have the tell-tale re-routed? I assume that re-routing it gives a better idea regarding the power of the water pump, but perhaps not.
BTW, the engine runs perfectly, outside of some warm weather startup difficulties. It seems to flood easily, and I could only start it the other day by NOT engaging the choke.
