thirdgen87
- Aug 16, 2008
- 8
hi all, i just picked up a gls175. i hooked up a new battery. turned the key to start and nothing. no juice to motor. all my guages work. tilt and trim work. but no juice. its a 70hp johnson. now. the key switch. is off, run and start. the start has a spring like action where as if i release it it will go to run. also with the push the key in for choke fuction. now. i got under the dash. there seems to be a red and blACK WIRE OFF THE IGNITION SWITCH. there was a button like switch on my floor. with a red and black wire as well. the switch on the floor. goes into the dash. with a spring load behind it. as in when you push the button it comes right back. looks like a spark plug. does anyone know if this has anything to do with power to the motor. of what the h@ll this button thing is? thank you for your help in advance
