Starter solenoid wiring help needed
kwt600
I have a 02 150 hp johnson ocean runner. I need to know which wires go where on the solenoid. I have 3 red wires and 2 black wires that go on the big terminals, not including the main battery cable. Then I have one yellow with red stripe and a solid black for the small terminals. Thanks in advance
boobie
Re: Starter solenoid wiring help needed
The yellow/red wire and the other small black wire go to the small terminals on the solenoid. The red wire from the starter goes to one big terminal of the solenoid. The other red red wires go to the other big terminal on the solenoid. All the black wires go to ground on either the solenoid mount bolts or where the negative bat cable goes on the block.
