shelikesit
- Nov 23, 2005
- 171
Not sure if this post goes here, but being new and able to listen to people in the know, this article here for starter trouble was perfect.
http://www.iboats.com/bbboard/bbBoard.cgi?a=viewthread;fid=24;gtid=1104170
When someone says to do tests before swapping parts he's trying to save you time effort and money. Now, I'm a firm believer, and a HUGE HUGE THANK YOU goes out to those that recommend this.
They obviously know what they're doing.
My problem was the solenoid, my big problem was I would of changed the ignition switch, neutral switch, solenoid and starter and not necessarily in that order.
Instead I found the post above, did the checks as stated and when power or ground didn't get by the slave solenoid, I found my problem.
So in 30 minutes and less than 20 bucks later, the boat starts fine, shuts off then starts again, and probably a day of jumping around ended quick.
Thanks to all of you, especially the guy who loves to say, do checks before swapping out parts.
Thanks.
Thanks.
