Hello,
I noticed today while working on my trim sender that there was some play in my alpha one 1st gen hinge pin. I pulled off the sender, got the special tool out and wentvto see if it was tight. Well it turned very easy, and never would get tight. If you wiggle the drive you can see the pin move and kinda back out a bit. All this wouldnt be a problem if the whole thing was old and it was time for new bellows and such. How last year in june the drive shaft ujoint broke and made a mess of the gimbal housing. I had all of it replaced, transome plate, bell housing bellows the whole nine. Now im having this problem.
I dontvwant but im about to drop the lower unit and pull the pin out andcsee what ihave. Either a broke pin, or a striped thread.?
My question would be does anyone know of a fix for this scenario? I.E. bigger hinge pin, some J.B. Weld or will i have to replace the gimbal ring? Or is there a draft that the pin screws into that could be replaced?
I thank you in advance for any and all help.
Michael
Michael
