I got a crusader 270 model. After about a half an hour of driving it will stall. When it stalls it surges and then is hard to start, i have to pump the throttle. I already changed the fuel pump, the filter in the carb, and the remote filter, there is also another filter on the engine i didn't change but was very clean.
It seems like it is a fuel problem because of the way it surges when it is about to stall. It looks like someone takes the throttle and pushes it down then up then down etc....and how i have to pump the throttle to start it makes it seem like it is fuel.
I do see fuel going into the carb though at the dock i disconnected the throttle and pumped it with the engine running and fuel looks like it is going in just fine.
Can it still be the carb, any other ideas?? It is so hard because it doesn't happen for a while after we start the engine.
Also, when i am running i have it at about 3000rpms for that half hour before it dies.
