SaltwaterBlueFin
- Jul 17, 2002
- 5
HELP. I just had impeller and lower water pump replaced after a major overheat. I have a Merc. 3.7 4 cyl. I believe Alpha 1. I/O. 190 Hrsp. After getting it back from the shop I took it for a test run.. Seem to run just fine temp was stable at about 140-145. After about an hour or so the temp moved to 155 and then the engine seem to short out as if there was not any fuel getting in to the carb. After cooling down and arguing with the batteries that acted dead it did start back up and again after cruising for a short distance it did it again and again.. I did clean the fuel filter and the filter that goes into the carb, took it out again for a run and after an hour and the temp jump to 155 or so same thing all of a sudden cruising just fine and then shut down. Please any help.
