After researching the forum I believe I have a non OEM stator. I have a black box between the stator and the switch box and the forum tells me it is called the stator adaptor. I do not have any ignition or charging problems it is I just want to know what is the adaptor for. If I were to replace the current stator should I look for a red or black stator and with or with out the adapter? If it was an upgrade what is the reason? I cant find a complete answer on the forum
I dont like the idea not having the OEM stator on the motor mostly becuase a couple red wires have been terminated at the switch box, they must have been for something. My motor is a 1995 Sportjet 120 in a F14 SeaRadyer. Any insight is helpful
Would this part #, 174-9873-16, work better then the orginal or the one I have.
http://www.boatfix.com/bykeywordnew2.asp?textfield=398-9873A39&texttype=2&submit=Go
Thanks.
Thanks.
