I have a 1985 85HP Force that has a smokey and very STRONG smelling exhaust. I have rebuilt the carbs, replaced the fuel pump gaskets, cleaned the puddle drain fuel recirculation system, and have run ring cleaner through. Compression is @ 130-135PSI uniformly on all cyl. Plugs are wet with some black carbon. When engine is accelerated it misses a little and leaves a smoke trail for a few seconds until it clears and then seems to be running great. I have the correct prop and am getting 5300-5450 RPM at full throttle. The engine runs great at cruise power but quickly begins to gag everybody after a few minutes at idle speed. I have adjusted the carbs as spec. in manual. I have also noticed occasionally that one or two of the carbs mixtures can be set all the way in and the engine will sill idle without popping and then quitting.(screws are not dented and have not been torqued down). This has been an on going problem and I cannot seem to get the problem resolved from local experts without replacing the engine. If anyone can help me I sure would appreciate it. Thanks.
