Paul Haldeman
- Sep 23, 2002
- 5
I have a 1993 5.8 EFI OMC Cobra on my Seaswril 190SE. It has two fuel pumps, a low PSI one that advances fuel from the tank and a second one that is a high PSI pump that feeds the fuel injectors.<br /><br />I have gone through 5 of the low PSI pumps and 3 of the high PSI pumps. Why? I use the boat all year round (so. Cal), I use additives to keep the water from seperating, I drain the separator. I use Chevron Tectron or 76 Union fuel recommended by my mechanic. Still I go through these pumps at $200 a pop. And they always go bad just before a nat'l holiday like Memorial Day, July 4th, Labor Day.<br /><br />Has anyone else run into this EFI fuel pump problem? My last one lasted two boat trips. I'll be sending it back to OMC or Bombadier or whoever for analysis.<br /><br />Standing by if you can solve this mystery. (Does this site have a spell checker?)
