Shutting down when on neutral
edu01jose
Having this problem since I bought the boat.
It's a 200HP Mercury from 96.
When I put the motor on neutral it turns off. If I give it a little gas it works fine. Only dies when no gas is applied.
What should I check first?
Thanks
CharlieB
Re: Shutting down when on neutral
What model motor? Carb or EFI?
A carbed motor could have a problem with dirty idle circuits not passing enough fuel.
An EFI could be idle timing messed with.
edu01jose
It's the carb version.
I'd like to do whatever I can first before calling a mechanic.
Any suggestions on what to look for?
Thanks!
