When I restored the boat this past year, I noticed it was a bit tricky torquing down the transom caps - I probably had a bad angle on the drilled transom holes… Anyway, it finally “popped”! Being 50 years old doesn’t help, I’m sure…What happened to 1 you had back in Oct 2022? Wasn't missing then
Thank you for all the suggestions! I think I’ll try my local fab shop first to fix the break if possible… for some reason, I assumed that cast aluminum wasn’t repairable - happy to learn that it might be! If that doesn’t work, I guess my fall back will be a set of aftermarket cast aluminum replacements w/ handles, but I’d rather avoid dropping $200 on it. I’m not looking for exact original or perfection, but I’d like both sides to at least match. I’ll follow up on this thread with whatever my ultimate solution ends up being…Searching for a Starcraft transom cap to replace a broken one on a 1974 12ft Seafarer. Suggestions appreciated….
Do you not understand the OPs issue with aa broken corner cap, or do you have aa similar issue and you are hijacking a thread?I can't able to understand your issue can you provide more information? Need more detail to fix this.
Well, it took me a while, but I finally got my repaired transom cap back from the fab shop - I’m really happy with it, and appreciate all the suggestions. $30 bucks, and a bit of a wait, and I’m back in action with the original part!Searching for a Starcraft transom cap to replace a broken one on a 1974 12ft Seafarer. Suggestions appreciated….
