dls322
- May 10, 2007
- 380
Hi Everyone.
I just finished re-decking my project pontoon. After finding out my deck was not as good as i previously thought, i figured it was better to just replace it instead of putting nice carpet over junk wood. i will add some pics.
My question is should I be adding some kind of sealant to the wood? The deck is Marine Grade 3/4 plywood that is not pressure treated (because of the reaction to aluminum). I sealed all the bolt holes with caulk and sealed between the sheet gaps and i also rubbed some caulk around the edges of the wood. I also laid down rubber weather stripping on all the cross members that the wood will rest on. I did not "seal" the wood though. I have read many posts on people saying that:
-Marine plywood should be left unsealed and that it's fine how it is...
-Other people say if you seal it you are trapping in water and it will rot..
-And then other people say you should seal it to make it last longer....
I'm kinda confused here....
I already put the carpet down so the top deck is how it is, but should i apply a sealant to the underside of the decking??
I'd like to do the project correctly and get 8 years out of the deck if possible. I leave the boat in the water at our dock for the summer 4 months, but when it's not in use will have it's cover on, and in the winter it's fully covered up and sheltered.
Seal the bottom or don't seal the bottom....the million dollar question! lol
Thanks
Thanks
