Re: RPM drops when I Adjust trim or tilt
when you are on plane trimed and running smooth, if you engage trin up for a second and the rpms drop 2/400 rpms, check stator output to powerpack. Engine may run rough for a few seconds.<br />There is old OMC service bulliten about this for 35 amp stators.<br /><br />Edited 6:30<br />Other post said engine surging. Time for compression check. Check magnets in flywheel, ignition systen check, Fuel pressure and vacumn.
