Re: Rewinding Steering Cable
This is how I attempted to rewind the cable.<br /><br />I hooked up one of the pulley ends to the motor and left the other unhooked. I then wrapped the cable around the steering wheel drum as tight as I could (I started wrapping in the middle of the drum). Then I kept tension on the cable until I could hook up the second pully end. This seemed to work, I would turn the wheel and the motor would respond. However when I get to the end of one direction the wrapped cable spins up/down the drum (depending on the turning direction of the wheel) until it gets to the edge of the drum where it stops and I can't turn it no more. How do I get the cable to lock once it reaches the end?
