ailurion
- Sep 7, 2013
- 22
Hi everyone. I'm new here and just want to say thanks first to the wealth of information I've gleaned just reading around, but there has been a bit of discrepancy in some of it, and I would like some clarification as well as guidance in my project so it goes as smoothly as possible, and ends up the best quality. So I suppose first I should show you what I am working with:
Like I said in the title it's a 14' Jon boat, the brand is DeSoto Mfg. and Supply Co. Inc. which is now defunct, the boat seems to be of good quality despite its apparent age:
If anyone can tell me anything about this particular model, such as the year or original specifications I would really appreciate it.
I have stripped it down of all the odds and ends that were added over the years by previous owners and washed it out. It is almost ready for sanding and primer outside of a few concerns I have. I plan on sanding, primer, sealing, painting, lining the hull, decking, carpeting, and rebuilding the transom. So I have questions about almost all of it:
1.) Question sufficiently answered through feedback and research. I will be using zinc chromate primer.
2.) Question sufficiently answered through feedback and personal decisiveness, I will use a sealer on the rivets.
3.) Question sufficiently answered through feedback. Paint on bed-liners are a waste of money and time.
4.) Question sufficiently answered through feedback. I decided to replace the old foam with polystyrene insulation foam.
5.) Question sufficiently answered through feedback and personal decisiveness. I decided for the transom I would remove the rivets from the top lip of the boat, and pull it out so I can construct a one piece transom. I've also decided to forego the marine grade ply since I will be sufficiently coating and reinforcing it with the proper resins. The A/C Fir ply is acceptable.
6.) Question sufficiently answered through research and personal decisiveness. I will be coating the decking in epoxy resin.
7.) Question sufficiently answered through feedback and personal decisiveness. I will be decking the entire bow for storage and a casting deck, the seats, and the floor between the middle and back seat. A second storage area is a possibility. I will lay cut sheets on 3/4" polystyrene foam over the water channels (keeping them open), and under the decking to add flotation and lessen the chances of debris getting in under the deck.
I think that is it for now, I am open to other suggestions and ideas that would make things easier or better in the long run. Thanks for your time guys.
