Re: Replace Transom Seal/Boot:
You can replace it, be careful with the screws that go into the metal frame with secures the boot to your stern-----you need a good sealant on each screw and on the entire boot or you will be taking on water.<br /><br />These are a pain. If it was punctured while underway by an object underwater, your insurance should cover the replacement---just a thought.
