<br />Try heat, if it doesn't have a rubber sleeve in the hub. Use a propane torch and evenly heat the whole hub area. The prop will expand faster than the shaft. Use a light hammer and tap everything that won't bend or break, as hard as you can without being destructive.Originally posted by copycat:<br />i am having a hard time removing the prop from a '71 Merc, i've sprayed it with wd-40,<br />and others. it just won't release off the shaft...while using a puller on it. any ideas<br />other than cutting it off?
