drun_trucker
- May 24, 2015
- 52
1994 GM 4.3L V6
balance shaft
NON Vortec heads
Thunderbolt IV ICM
Crank, cam, and balance shaft timing marks all aligned on install. TDC has rotor pointing at #1 cylinder on compression.
***Initial Problems or Areas of Concern***
1. Air/Fuel screw in carb was damaged by previous owner and was replaced during the rebuild process. Not sure where to set it to get the best air/fuel mix while trying to time.
2. The rebuild block is from an automotive application. It seems that the timing cover and the marine harmonic balancer to jive. I had to bend the flange with the timing marks up, grove it out and bend it down to ride just above the pulley. I'm not sure at all the the timing marks are in the right location.
I know I'm missing information but I have been up down and around sideways trying to figure this out and my mind is a bit fried. If there is more that needs be known just ask or point me in the right direction. PLEASE
balance shaft
NON Vortec heads
Thunderbolt IV ICM
