DeepBlue2010
- Aug 19, 2010
- 1,305
Hi everyone,
My hull sides (under the rub rail and above the deep V) is in horrible shape and I don?t know what to do. I was trying to fix few digs and scratches with a gelcoat repair kit and the process turned into a nightmare. When I was trying to sand the past, some areas started to thin to the point that I can almost see the raw fiber behind and some areas actually did show it. I used a sand block for wet sanding and I didn?t apply any uneven pressure ? not that I am aware of anyway ? so I don?t know what the real reason for this problem is. However, I need to fix it now. What kind of preparation I need to do before shooting the new gelcoat? Should I sand and fair the whole hull (I mean the sides) or the new gelcoat will take care of the sanding marks and scratches that still showing. Some people said I need to get the hull silky smooth before shooting and even buff with heavy duty 3M compound. Others said NO, just sand the whole thing with 220 wet - just to get t rough for the new GC - and shoot over that. The current status of the hull is sanding scratch marks that 3M heavy duty compound was not able to remove and some oxidization here and there. Given that, what is the right course of action? Your help is greatly appreciated.
