Dave Brick
- Jul 14, 2010
- 63
When winterizing, I'm supposed to spray fogging oil into the carbs.
To access the carbs, I apparently need to remove the "air silencer", ie, the cover over the carbs.
When I remove the silencer, there appears to be a gasket under it.
Do I need to replace this gasket every time I remove the silencer? That seems to be the recommendation for most gaskets.
Motor is 1992 60 hp ELENE.
